Issue with such HDR HDTV movies
I have a problem reading UHD HDR content on Infuse.
If I run a 4K HDR movie, no problem (I have the HDR logo on my Samsung TV).
If I run a 4K HDTV record (MPEG-TS format, HDR10), I do not have the HDR logo. HDR is on if I directly play the video on the TV with the Samsung player.
I don’t get where the problem is coming from … Any idea ?
Are you sure that it is HDR10? Since its source is TV its likely HLG (hybrid log gamma) as this is the HDR standard for television while HDR10 is for streaming and discs.
Please post mediainfo of said file.
https://mediaarea.net/de/MediaInfo
I guess it is HDR10…
Vidéo ID : 1
Format : HEVC
Nom commercial : HDR10
Profil du format : Main 10@L5.1@Main
Identifiant du codec : V_MPEGH/ISO/HEVC
Durée : 3h 39mn
Débit : 18,0 Mb/s
Largeur : 3 840 pixels
Hauteur : 2 160 pixels
Format à l’écran : 16/9
Type d’images/s : Constant
Images par seconde : 50,000 Im/s
Espace de couleurs : YUV
Sous-échantillonnage de la chrominance : 4:2:0
Profondeur des couleurs : 10 bits
Bits/(Pixel*Image) : 0.043
Taille du flux : 27,7 Gio (99%)
Default : Oui
Forced : Non
Gamme de couleurs : Limited
Coordonnées de chromaticité : BT.2020
Caractéristiques du transfert : PQ
Coefficients de la matrice : BT.2020 non-constant
Mastering display color primaries : R: x=0.000000 y=0.000000, G: x=0.000000 y=0.000000, B: x=0.000000 y=0.000000, White point: x=0.000000 y=0.000000
I have another TV record which is HDR HLG and I have no “HDR” logo too
Would you be able to send in a sample file we can review here?
Your link is down but you can download it here :
links removed
Thanks!
Hi James,
Any news about the files ?
Quick update.
We’ve worked to add better support for HDR (HLG) videos, and plan to have these changes available in the upcoming 5.8.2 update.
