Hi.
I search for the subtitles from within Infuse. I use a Apple TV device, so I slide down to get the subtitles control, click on Get more, and then it connects automatically. I means OpenSubtitles.org.
I have Mister Ed season 1, and I’ve seen that episode 26 (Wilbur sells Ed) subtitles are listed as episode 25, while episode 26 is listed as (Ed cries wolf). Then Episode 25 (Pine Lake Lodge) are listed as episode 14. Almost every episode starting with episode 12 in the 1st season are wrong. These are some examples, I’ve got.
The proper list of episodes is in Wikipedia, and corresponds to what I have. Also, the description of each episode that Infuse itself gives corresponds to each episode according to Wikipedia’s list (and mine).
Actually if I could select which subtitle I want for an episode, that would fix the issue, rather than have OpenSubtitles.org fix everything.
Thanks.
