Issue with paw patrol episodes
I’m having an issue with paw patrol. The show mostly airs per two episodes. But infuse will then just show episode 1,3,5 etc. Is there a way to remedy this?
Currently your only option is to have each episode as a separate file. You can follow the episode guide on thetvdb to see the episodes. https://www.thetvdb.com/series/paw-patrol/seasons/official/6 and if you have them two per file split them and rename the individual files.
If you like you can add your support to a thread in the suggestions forum for the feature of multiple episodes per file here. Multi-Episode File Naming?
Yes well they are downloaded in pairs. So that’s not an option. I’ll have to settle for it then ?
