Issue with icloud sync?
Hi
What does icloud sync do? If I add a new share or make changes to what’s included in my library etc I seem to have to do the same process on each device.
Does it just retain watch history/progress?
It will sync shares, textual metadata, corrections to metadata, and other prefs.
If you have a new device without Infuse and you download Infuse then launch it, it will set up your shares with your library and metadata along with the other prefs.
You can watch this if you launch the fresh copy of Infuse and when it comes up to the “Lets Add Some Shares” screen just ignore it and go to the Settings > Library screen and it will be showing syncing with iCloud. Just let it set there for a while (time depends on the size of your library) and it will load everything.
