Hello,
First I would like to say that I have been using infuse pro for about 3 years and love it!! I recently acquired a 4K UHD disk and found that it was not playing in version 4. After some googling I saw that their was an infuse 5 pro. So I bought it and they play great!! Then I noticed that my original ISOs I keep in the same directory of my MKVs started to now show up. Quickly I saw that they can play!!! This is amazing because I have consumed 17.3TB of disk space keeping the RAW ISO and the MKV I make from them so I can watch on AppleTV. So then I thought I could start to possibly delete all my MKVs from all 243 movies I have because now it plays the ISO. I tested a few and they worked great, however, I tried to play an ISO that has Java BD Protection and found that the scenes are out of order and the copy protection comes on. Luckily I kept all the log files from AnyDVD when I ripped tham and it tells you which MPLS playlist is correct. So I attempted to watch John Wick (which its correct MPLS playlist is 202), so I click on the ISO and changed to title 202 but found it still has the incorrect scenes. So I’m guessing the titles that Infuse locates on the disk are not 1 for 1 correlating to the MPLS playlist. With all this being said how can I find out which playlist is 202? Once I can do this I can free up 8TB by deleting all my MVKs and only keep ISOs!
Thanks in advance for your help.
