ISO made with Disk Utility MacOS does not play
Goodevening. When I download ISO files and play them in Infuse 6 there is no problem.
But when I create an ISO file myself out of VIDEO_TS map using Disk utility from MacOS (latest version) Infuse 6 does not play the created ISO file. It says “error loading the file”. What do I do wrong? Thank you.
It’s probably not compliant. Use the command line:
hdiutil makehybrid -iso -joliet -udf -udf-volume-name $folder -o $fullpath.iso $fullpath
