ISO Blu-ray file track selection
I suspect your development team are working on a fix already but I cannot find any discussion about the issue I have recently found. Using an ISO Blu-ray file of ‘Gravity’ Infuse 5.4.2 does not recognise the main movie track. It picks the longest track available which happens to be the extras compilation and plays that. Can we have a video track selection method please. With the software in its present form I am unable to access or play the main movie which kind of defeats the object! Otherwise great software for accessing most file formats. Well done!
You can actually do this in the current version through the Video tab in the Playback Menu. This menu can be accessed by swiping down while a video is playing. :slight_smile:
Thanks James that’s something I should have done prior to my comment. Keep up the good work
