Is this a problem or not ?
I ran the command : sudo dd if=/dev/disk0s2 of=/Users/frontrow/Documents/recovery.dmg bs=1m
When I didn’t need to as I have the new ATV so AFP support is not their according to the wiki…
Will this cause other problems ? Can I revert it, should I ?
All that means is you have an image file in the Documents folder taking up space. I would transfer that to your Mac/PC and then delete it off the Apple TV so you can reclaim the space. If you leave it there, there will not be any problems.
Thanks will do!
All working…SMB Mounts to my NAS etc…
