Is there any more options other then TMDB?
Hey I was wondering if there was a different option to use for meta data organization other then TMDB when using infuse ? The issue I’m having with TMDB is the wrong meta data being used for different dubs or even DVDs, they have this weird rule where they don’t allow different dubs, and will delete the contribution once its uploaded, which is in issue that causes incorrect labeling. IMDB and TraKt both have correct meta data for the anime I have, where TMDB doesn’t allow it ? Doesn’t make much sense the anime im talking about is Dragon Ball Z ocean dub
There aren’t other choices in Infuse by itself but if you use Plex, Emby, or jellyfin I believe they offer other options that Infuse would pull in when connected to them.
Probably the easiest way would be to create a NFO file for the ones that TMDB doesn’t have and then you could have it present as you want.
IMDB and TraKt both have it ready to go, but I guess infuse only supports TMDB, I made a NFO on grok I guess I’ll try that route, Is there a guide on putting NFO files for infuse
This users guide has a sample nfo file you can start with.
Hi
i use tinyMediaManager. It work well.
