Is there an actual downside to Tethers JB for ATV's?
Hello everyone :slight_smile:
I was wondering… if you do a tethered jailbreak with iPhones, iPads or iPod Touch’s, you have to connect it to iTunes whenever you do a reboot of your device. But this isn’t really the case with Apple TV’s since they’re always on or in sleep-mode.
Does that mean that as long as you don’t disconnect the Apple TV from a power outlet, that you effectively never notice any downsides with a Tethered Jailbreak? So as long as your Apple TV is hooked up to a power source and active and/or in sleep-mode, you’ll never run into the downsides of Tethered Jailbreaks?
Thanks for the information :slight_smile: This question has been bugging me for a while now, hehe.
Cheers!
Correct. As long as the power remains connected you won’t see any issues with a tethered jailbreak.
Sleep mode and ‘soft’ restarts (after installing/updating plugins) are ok.
Oh, that’s great news! Thanks for the reply, and I’ll be updating right now :wink:
Ok so I get that the sleep mode and soft rest aka respring is ok with a tethered jb.
What about the reboot via nitoTV or by holding menu, down? I have a hunch that its not good with a tethered jb. need to verify though.
Also i noticed that holding select for a few seconds shuts the atv 2 off, is it turning off or going to sleep. Is this ok with a tethered jb?
The reboot option in nitoTV and holding menu + down will restart the AppleTV and require a new tethered boot.
Holding select while at the main menu will put the AppleTV into sleep mode which is ok.
