Is it possible to group by show
Hello,
I have a folder name “TV Shows” where I have other folders with all my TV shows, per season.
In Infuse on iPad or iPhone, is it possible to have a view where it shows all my TV shows per nam and inside all the different seasons, and not directly a TV show per season on the main page?
It’s like that in Infuse on my old Apple TV 2, but it’s not like that on my iPad or iPhone.
Thank you for your help.
Regards,
Eric
Yes, if you group your series into folders organized by season, Infuse will display them exactly as you are hoping (a main series thumbnail, and then seasons displayed underneath that).
More info on this can be found here.
http://support.firecore.com/entries/23704917-Metadata-101
