I have a friend who has a custom Apple Tv Box with all kinds of goodies loaded onto it.
Is it possible to be able to “clone” his box and copy it onto mine fairely easy?
Do I just WinSCP into the box and copy all the files from the root directory to my box?
I tried to do this I can see the layout but nothing seems to work/function properly.
No as the files would be in use. You would also require yours to be jailbroken in order to telnet/sftp into the device. And if it is jailbroken you can already do whatever your friend has done.
I know how to do the jailbreak but he has such a nice skin on and seems like everything is set up custom and works very nice. Also if its possible to just clone a box it would make it easier so I don’t have to go in and install all of the ad-ons they would be automatically there.
