thanks this is a nice improvement. There is a bug in landscape mode on the bigger screen. You can’t scroll a movie or TV show page. It scrolls, but once you get to around the “Cast and Crew” section it keeps jumping to the top. You can’t scroll down past that part. I’ve forced quit the app and restarted it, but same issue.
Thanks. We caught this one too. Fix in progress!
Also there is a bug with the logo in closed landscape layout:
And two bugs in both layouts:
@james Do you have any thoughts about my suggestions and a little preview of the new design?
I noticed a bug in the new update, it is impossible to scroll when you open the cover of the movie. I haven’t tested other devices or media libraries, at least I have a duo with Plex on my iPhone.
2AYHW
I’m sure you’re on it, but just realized the scrolling bug is there when the Duo is closed too.
Poster needs to be moved to the side or shrunk? Shouldn’t have to scroll so much as well. Looking forward to the Duo improvements.
The brightness slider is not working on inner screen
% change but nothing happens on the inner screen
Also having the same issue
We have a beta of 8.5.10 available today which includes a set of improvements for the Duo.
If you’re interested in giving this a try please drop me a PM. ![]()
Hello,
I have a weird infinite scroll bug on iPhone Duo when scrolling on the detail of a media. But the app looks awesome.
Thank you !
I moved your post to a thread discussing the Duo. You may want to scan through it. ![]()
Can’t find the option to pm, definitely interested for joining beta if slot avalaible, pro user too.
Click on the persons pic/avatar/initial on their post. ![]()
yes and ? maybe i dont have the option cause i’ve just created my account today ?
Bump on the bugs, just updated infuse for duo and I am also experiencing the same bugs - unable to scroll down, brightness sliders (gestures and settings) does not work - and not sure if it is ios or infuse but when trying multitasking, infuse turns to black but audio is still playing. You have to swipe at the lower part for the picture to come back.
