iPhone 14 pro max problem (BUG)
When I watch hdr 2160 on iPhone 14 pro max I can see a gold line at the corners
(The colour depends what wallpaper you use)
Do you have Infuse 7.4.5 installed?
Does this happen with all content?
Yes I am using version 7.4.5
as long you fill all screen and the pixels touch the right and left corner , and you can see that only when the player changing the hz on the screen
Another example with sdr content
Thanks for the info, we can look into this.
Does adjusting the zoom setting make a difference?
I meant as you can see in the image , if there are black bars there is no problem
Only when full screen and the pixels at the corners need to turn on
We have not been able to replicate this issue on iOS 16.1.1 and Infuse 7.4.9 with a variety of different video types (SDR, HDR) different zoom/aspect ratio settings, as well as several wallpaper variations and setting.
Are you still seeing this with the latest versions of iOS and Infuse?
It happen when the video is full of screen from left side to right side
when tap the screen,it become normal,but happen again a few seconds later
Which version of iOS and Infuse are you currently using.
We haven’t been able to replicate this here on iOS 16.2 and Infuse 7.4.10.
ios 16.2 infuse7.4.10
Would you be able to upload one of the videos you are seeing this issue with?
http://upload.firecore.com
I already upload Top.Gun.Maverick.2022.IMAX.2160p.UHD.BluRay.x265.10bit.HDR.DDP5.1.Atmos-RARBG.mkv
the issue is quite obvious especially at the begining when the background is black
@james use a black or dark background image to you’re iPhone , u will see the bug more clearly
From iOS 16.3 release notes:
Fixes an issue where horizontal lines may temporarily appear while waking up iPhone 14 Pro Max
Maybe it will be fixed after this is released
