iPadOS Public Beta [Problem with sharing menu - Send to Infuse]
iPadOS Public Beta
I am having a problem with sharing menu - Send to Infuse option is missing.
I’m trying to send an .mkv I have stored on an SD reader to Infuse in the files app.
The option was there then I tried to use it and it has disappeared.
Just reporting this as possible bug.
Thanks for the report. :slight_smile:
Same thing down here with iPadOS 13, developer beta 3.
As a side note, the Sandisk dual drive usb-c/usb-a part # SDDDMC2-064G-GA46 sold by Apple is not detected by the files app (https://www.apple.com/shop/product/HLNB2ZM/A/sandisk-128gb-ultra-dual-drive-usb-type-c)
The one that works for me is Sandisk dual drive part # SDDDMC-064G-GA46 (https://www.ebay.com/itm/Brand-New-SanDisk-64GB-Dual-Drive-USB-C-Flash-Drive-SDDDMC-064G-GA46-/263676843174).
Both drives are ex-FAT formatted, MBR.
Carlos
P.S. The non working one is seen by Disk Utility (Mac) as “SanDisk Ultra USB 3.0 Media”. The working one is seen as “Generic- SD/MMC Media”. That might be the key to the issue
According to our tests, this appears to be resolved in iOS 13b5.
Please let us know if you see any other issues.
