iPad Continuous Play
If I’m on my IPad and I start a series with additional episodes left in the season/series from the “Up Next” (for lack of a term) section, playback will stop after the episode is done even with Continuous Playback enabled. Anyone know if this is intended or if there is something else that needs to be done to get that to work?
Are both using the same user ID for Infuse? Is iCloud sync turned on and has it completed before you start?
