Ipad Air - Infuse support for Lightning HDMI adapter
Hi all
I have Infuse 2 pro and an Ipad Air. I’m contemplating buying the vastly overpriced Lightining AV adaptor. Does it work well with Infuse/iPad Air? Is there anything I should know before handing over my money? I’m intending to use it to play a broad spectrum of files (all of which Infuse is happy with).
Many thanks
Yep, the Lightning HDMI (or VGA) adapter works great with Infuse. If you have an Apple TV you can also AirPlay a wide array of formats that way as well (may be a better value since buying an Apple TV isn’t a whole lot more than the adapter).
