Internet Radio not working
The internet radio option is not working  when selected on the apple TV.  The ATV errors and must be rebooted.
Any ideas?
This is a known issue when 'ATVFiles (beta)' is installed. Do you currently have this app installed through the Maintenance --> Manage Plugins menu?
You can easily remove the ATV Files (beta) item by following the steps here.
I will try it and let you know.  Thanks
Deletion of file worked.  Thanks
8)
Hi, this worked for me too.  Any idea when ATV Files will come out of beta and be compatible with the radio?
Adam
