Installing Perian
When I select to install Perian it tells me that Apple H.264 is active and do I want to disable it.
Will my Apple H.264 content still play if I disable it and activate Perian?
Thanks for the information.
You do NOT want to disable the Apple H.264.
If needed, the ‘Apple H.264’ codec can be enabled or disabled through the Maintenance → Settings menu.
