Installing flash
Sorry I’m new to this. I just jail broke my ATV and it’s great. Got aTV flash and I went to a few places with online shows and it says I need to install adobe flash. Do I need MiRow?
Or is there a step I’m missing.
Sorry if this is a silly question but I need to know.
Adobe Flash is no available on the ATV2, so you will not be able to view any sites that require it.
Is there any program that will allow me to do this?
Not as far as I know.
There have been attempts to get flash working on the ATV2 - the Firecore blog talks about their experiences.   I think that they technically got it working, but that the ATV CPU could only deliver about 3 frames per second which made it useless for practical purposes.
Thank you.  What can I now do with my jail broken ATV? I have XBMC and Plex but I don’t really know what to do with them.
Forgive my ignorance.
I guess it is up tp you :slight_smile:
My main use of XBMC is to play media (video and music) off my NAS.   I do not use Plex.    When it is up to it I will prpbably switch to using the Firecore Media player isntead of XBMC.
In terms of using sites that need flash, then I think they are simply not options with the ATV2 unless they offer HTML5 media as an alternative
