Installing Flash Pluggin for Couch Surfer
I am trying to install the flash plug-in for Couch Surfer but I have run into a snag. I think I found the necessary components and I have the plug-ins in the right folder on the Apple TV. It also asks for a Core AudioKit Framework to be put into a specific folder on the Apple TV but I can’t seem to find this folder.
I am using Transmit to put files and the plug-ins on the Apple TV now but there doesn’t seem to be a way to get to the “system” folder that I need to put this framework into. Does anyone know what I am doing wrong?
Thanks for any help
You cannot copy files directly to the System folders using Transmit, or any other FTP program.
We have a step by step guide set up here:
Thanks for the help. I will give this a try.
