I currently have the 2.2 FW on my Apple TV with aTV 3.3.4 installed.
I am looking to upgrade to aTV 3.3.5.
No here comes my question, I use to install aTV the following way:
complete reset of the Apple TV (i then have the 2.02 FW on it if I reacall correctly)
install aTV via my USB stick
then use the Apple TV update function (which used to update to 2.2)
Now if I would update via Apple I would get the 2.3 FW which won’t work with the aTV software.
Thanks for this info.
Just to clarify, I will download aTV 3.3.5 install it on a USB stick - unpower off the AppleTV and insert the USB stick and repower the AppleTV and let the installation begin.
Once this is completed unpower the AppleTV and unplug the USB stick, then repower the AppleTV and I should then have 2.2FW with 3.3.5 AppleTV.
Last question, is there a need to update from 3.3.4 to 3.3.5?
Cheers
Well, I tried installing Quicktime once again yesterday… Still no go. I clicked on it in Maintenance… Let it sit for awhile… Never brought me to another screen to tell me it is working… Just sat at the menu… Lost all function to the remote. So, after awhile of it doing absolutely nothing, I held the Menu and - key and restarted it.
Any ideas as to how to install Quicktime? I’m using 3.3.5 and 2.2. Thanks.
Even though it seems as the system is frozen, it is actually working. The file downloaded for QuickTime is about 60mb, and you won’t get a response until the download is complete.
An improved Maintenance interface with more refinement with better user feedback is in the works.
