Installation problem
Hello. Last week I bought aTV Flash (black) but it seems not to be working on my ATV.
Here it is what I am doing step-by-step:
  1. Restore and jailbreak using seasonpass. iOS version 4.3
  2. Connect to my TV. Turning on AirPlay and Home Sharing.
  3. Runing aTV Flash (Black) on my macbook pro and I am getting this “The installation was successfull” message
  4. After a regular flash/restart I dont see nothing new appears on my ATV
Also tried to install some plug-ins (maintenance; nitotv; plex …) through SSH and terminal says that everything is installed. But again no new menus on the screen.
The support team told me that fc_installer.log seems okay.
I would be very thankful to everyone who can help me. Thanks!
Hmmm - that’s a new one.
Perhaps try downloading the latest version of Seas0nPass, re-jailbreaking then reinstall?
Weird… Somehow the menus have appeared. I don’t know how exactly that happened and I don’t have a step-by-step solution…
Just keep trying if you are having the same issue. And yes I know how stupid that sounds… :))
