Ive managed to download the dmg file for my iMac but after I drag it to the applications folder it doesn’t prompt me (step 3) to choose the destination (4 gig memory stick).
Step 3: When running the aTV Flash Installer you will be prompted to select the flash drive you wish to use from the drop down menu.
I've saved it applications & then manually saved it on the memory stick but it hasn't installed on my 1st Gen ApTV?
Ok, so I attempted to do this again & after executing the downloaded file i did get the prompts but when i go through to the downloading stage on my memory stick it just freezes at 0% downloaded!! this is very frustrating for $40!!
