installation failed
I purchased atv flash 2.3 a while ago, and started to install it today. I enabled home sharing and airplay. Disabled firewall on windows pc. Doubleclick on the application and agreed with
software agreement, then it returns with screen, you are using the latest version of a ATV flash (black). proceedwing with searching for devices and found the
atv with the correct IP adress, hitting next… transferring files… and after 2 wseconds returned with… installation failed… huh ?
please help…
problem solved… turned out that i forgot to first jailbreak the atv, after that i was able to transfer the files…
