Installation Failed (Media Player) 4.3.1
Tried installing Media Player following the 4.3.1 jailbreak using the latest Pwnagetool and the latest firmware. This is the message I'm getting:
E: Broken package
ts...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
com.firecore.media: Depends: afpfs-ng but it is not installable
Depends: org.xbmc.xbmc-seatbeltunlock but it is not going to be installed
Haven't got anything else installed except for Maintenance at the moment.
I get the same message, same jailbreak.
update nitotv.  that apparently fixes it.
alternatively you can fix it yourself by adding Saurik's source via SSH - once you log in, the command to run is:
p.p1 {margin: 0.0px 0.0px 0.0px 83.2px; text-indent: -83.2px; font: 12.0px Verdana}
echo 'deb http://apt.saurik.com/ tangelo-3.7 main'>/etc/apt/sources.list.d/saurik.list
then you should just be able to install media player and all it's dependencies.
worked perfect...thanks
