Installation Failed! from Maintenace Menu
I jailbreak Apple TV2 and install XBMC using Maintenance Menu
E: Unmet dependencies. Try ‘apt-get-f install’ with no packages (or specify a solution).
I get few lines  said but it is not going to be installed
Does any one has any idea how do I install rest of the packages from Maintenance?
I would like to install Couch Surfer Pro and Rowmote. I did installed nitoTV and XBMC and right after I try any other package I couldn’t.
Please help and advice.
Thanks,
JR
Does anyone has any advice regarding
Please post and Thanks,
Redo your Apple TV seen you have some issue don’t waste time figuring out why take longer than just restore it but be sure you have saved blobs for it otherwise you can not
restore it
Thanks for your advice but I did saved my BLOBS but this issues or error message is appear on Maintenance side. Two apps installed and if I want to install rest of the Apps such as PLEX or Rowmote or HD Remote I keep getting apt-get -f install and I am not sure how to use apt-get -f install.
Thanks,
JR
If you are using mac, open terminal, ssh into your atv 2 and run mentioned command i.e “apt-get -f install” without quotes in your case and it’ll fix it and if you are on windows download PuTTy and ssh into your atv 2 and run the command. You will be all set once you are done.
Note: Watch out for space and dashes. You should type exactly what is shown on your TV screen when error comes up.
Thanks for your advice and I did try this command using MAC terminal and once I entered apt-get -f install then I reboot but when I go back to Maintance menu and try to install Couch Serfer Pro I still get same error.
What should I do?
