I wrote this piece as it might help someone.
At least you do not have to wade through all the topics to find the bits and pieces to get it working.
What i used:
[list]
[]MacBook Pro (2.5 GHz Intel Core Duo) MAC OS X 10.5.4[/:m]
[]Apple TV 160GB Software version v2.0 → updated to v2.1[/:m]
[]ATV Flash v3.2.2[/:m]
[]Philips 37PFL9732D connected to ATV with HDMI mode 1080i[/:m]
[]Conceptronic CH3SNAS 1.5 TB (sw. 1.03), samba shares[/:m]
[]Buffalo Linkstation (sw. v2.0), samba shares [/:m][/list:u]
Goals:
[list][]enable ssh, scp on the ATV[/:m]
[]mount the NAS shares to the ATV with samba (smb)[/:m]
[]play DVD (.iso) & mp3 stored on both the NAS[/:m][/list:u]
[color=red]Warning[/color] if you use AFP instead of SMB, don’t install the DMG in step #8. It will break it!
Start:[list=0]
[*]read the FlashDriveCreation.pdf and handle accordingly.[/:m]
[*]unplug the ATV power cord[/:m]
[*]insert usb key in the ATV[/:m]
[*]plugin the ATV power cord[/:m]
[*]let the ATV Flash program do it job[/:m]
[*]remove the usb key and recycle the power[/:m]
[*]start the terminal[/*:m]
[*]copy the file MacOSXUpdCombo10.4.9.Intel.dmg to the ATV with
[code]scp -1 ~/Documents/MacOSXUpdCombo10.4.91Intel.dmg frontrow@192.168.1.10:~/Documents/[/code]
note 1: the DMG file is located in mine Documents folder
note 2: the response is [b]frontrow[/b]
note 3: IP address of the ATV is [b]192.168.1.10[/b]
########### previous installation #########
I have made a SSH connection to the ATV before i restored the ATV.
Hence, the RSA1 key is invalid. You will get the warning message below.
Remove the file ~/.ssh/known_hosts (or the ATV entry in it) on your mac.
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that the RSA1 host key has just been changed.
The fingerprint for the RSA1 key sent by the remote host is
63:20:51:d5:32:eb:3f:6c:92:3d:fe:20:81:b4:d4:b2.
Please contact your system administrator.
Add correct host key in /Users/smiley/.ssh/known_hosts to get rid of this message.
Offending key in /Users/smiley/.ssh/known_hosts:1
RSA1 host key for 192.168.1.10 has changed and you have requested strict checking.
Host key verification failed.
lost connection
mbp:~ smiley$ rm .ssh/known_hosts
mbp:~ smiley$ scp -1 ~/Desktop/MacOSXUpdCombo10.4.9Intel.dmg frontrow@192.168.1.10:~/Documents/
The authenticity of host '192.168.1.10 (192.168.1.10)' can't be established.
RSA1 key fingerprint is 63:20:51:d5:32:eb:3f:6c:92:3d:fe:20:81:b4:d4:b2.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.1.10' (RSA1) to the list of known hosts.
Password:
Response:
MacOSXUpdCombo10.4.9Intel.dmg 100% 308MB 1.7MB/s 03:04
mbp:~ smiley$
[/:m]
[*]On the ATV navigate DVD > Settings > Install Software[/:m]
[*]choose the Install Turbo’s Kextloader [/*:m]
[*]choos the Smart Installer
To verify that one can mount a smb share,
type [b]mount[/b] at the ATV prompt followed by pressing the TAB key instead of the return key.
It should show:
-bash-2.05b$ mount
mount mount_fdesc mount_msdos mount_smbfs mount_volfs
mount_devfs mount_hfs mount_nfs mount_synthfs mountd
-bash-2.05b$ mount
[/:m]
[*]choose Install mplayer Codecs[/:m]
[*]navigate DVD > Network > Add Manual Share Point
Conceptronic CH3SNAS props:[list]
[*]IP address = 192.168.1.9[/:m]
[*]workgroup = intranet[/:m]
[*]share1 = DVD // read-only for all i.e. guest access[/:m]
[*]share2 = DVD-1 // read/write access for me[/:m]
[*]share3 = MP3 // read-only for all i.e. guest access[/:m]
[*]share4 = MP3-1 // read/write access for me[/:m][/list:u]
Which results in:[list]
[*]Mount Name = dvd //can be any name[/:m]
[*]Mount Address = 192.168.1.9[/:m]
[*]Mount Type = smb[/:m]
[*]Require Authentication = No[/:m][/list:u]
Note 1: the Mount Type is not asked, you will have to set this your self.
Note 2: although mine workgroup name is not a standard name, samba will establish a connection.
[/:m]
[*]the share dvd is added to the DVD > Network. The play/pause button will mount this entry. [/:m][/list:o]
Result:
Movie files stored on the share dvd are now accessible by navigating DVD > Files > dvd.
Opening these files through Media > Sapphire OR Files > Movies, works only with MKS files and not wmf, iso, ts_video files. :?:
ISO formated DVD’s containing DVD menus result in back screen but the menu sound is played.
Random screen sizes i.e. 720 on 1080, next instance correctly.
Playing MP3 files, is a nightmare with DVD > Files.
Cannot stop a mp3 from playing and accidently pressing the play button on a another mp3 file results in sound mix of both.
Stopping it can only be done by rebooting the ATV.
