InfuseSync Plugin for Jellyfin not exists
Hola. Tengo Jellyfin instalado en un NAS de Synology. Cuando accedo a través de Infuse me recomienda que instale el plugin InfuseSync en el servidor de Jellyfin. El plugin aparecía hace muchos meses pero ahora ya no. No lo puedo instalar porque no lo encuentro.
Hello. I have Jellyfin installed on a Synology NAS. When I access through Infuse it recommends that I install the InfuseSync plugin on the Jellyfin server. The plugin appeared many months ago but not anymore. I can’t install it because I can’t find it.
The steps for installing InfuseSync can be found here.
Gracias, la solución ha funcionado. Únicamente quiero añadir dos detalles: 1.- Cuando añades el repositorio es necesario detener el contenedor de Jellyfin y volverlo a poner en marcha para poder instalarlo, de lo contrario da error. 2.- Es necesario cerrar Infuse en el AppleTV para que vea que el plugin está instalado, si no, sigue pidiéndolo.
Thank you, the solution has worked. I only want to add two details: 1.- When you add the repository it is necessary to stop the Jellyfin container and restart it to be able to install it, otherwise it gives an error. 2.- It is necessary to close Infuse on the AppleTV to see that the plugin is installed, if not, keep asking for it.
I only see version 1.5.1.0. I already have Jellyfin 10.11
I’m utilizing this thread to report one issue I’ve found with InfuseSync and a new Jellyfin installation: Even though the correct repo is used and the manifest json has InfuseSync 1.5.2 listed inside, Jellyfin will only install 1.5.1 and not the very latest version. I don’t know what the reason for this is, but maybe @james you could take a look into this? Please let me know if I can provide any information around this. Thanks in advance!
The InfuseSync 1.5.2 update requires the server to be running Jellyfin 10.11. If you are running 10.10 then 1.5.1 is the version you will want to use.
