Today we’re happy to present the public beta version of Infuse for Apple Vision Pro!
This build represents a work in progress, and is still rough around the edges, but we are planning to have new updates every week (or so) - so things will continue to improve until the official release of 8.0 in Fall 2024.
How you can help
- Sign up for TestFlight
- Share feedback publicly in this thread to facilitate discussion with others
- If you find something that is broken, it may be helpful to submit a diagnostic report. To do this, simply tap the ‘Email Us’ option found in Settings, copy the 5 digit code, and post it in this thread with a description of the issue. Sending the actual email from the app is not required.
Activating Pro features
Existing Pro licenses will not transfer to TestFlight builds. The best option for activating Pro when using TestFlight builds is to use Trakt.
Option 1: Use Trakt to activate Pro (recommended)
- Ensure Pro is active on a device running the stable App Store version (iOS, Apple TV, Mac)
- Log into Trakt in Infuse on that device (create a free account if you don’t already have one)
- Log into the same Trakt account in Infuse on Apple Vision Pro
Option 2: Use TestFlight sandbox to activate Pro
Note: The purchase flow in TestFlight is notoriously buggy, so ymmv.
More info
- Install the beta from TestFlight.
- Select the Lifetime in-app purchase option (You’ll get a confirmation like this which clearly says you won’t be charged.)
If this still isn’t working, or you’re getting an error - then it’s likely there is a mismatch somewhere with your Apple IDs.
Tips for resolving issues
- Remove Infuse
- Sign out of the App Store
- Restart your device
- Sign back into the App Store
- Install Infuse via TestFlight
If you’re still seeing issues, you may need to check to ensure the Sandbox ID matches the one you are using for TestFlight.
This is found in Settings > Profile > Media & Purchases
What’s new in beta 9 (4963) 9/13/24
- Home: Re-added context (long-press) menus
- Home: Polished UI for empty screens
Click for notes on previous versions
What’s new in beta 8 (4953) 9/6/24
- Fixed playback quality for non-HDR movies
- Added markers support (e.g., Next Episode)
- Improved resizing animation when closing player
- Removed landscape lock setting
- Misc UI improvements and fixes
- Fixed UPnP server discovery
- Fixed flickering when changing playback speed in advanced settings
- Added Slovenian translation
- Improvements for SMB streaming
What’s new in beta 7 (4949) 9/3/24
- Fixed freezes and crashes
What’s new in beta 6 (4945) 8/30/24
- Option to auto dim background during playback
- Improved controls for resizing playback window
- Fixed resizing of very small and very large playback windows
What’s new in beta 5 (4941) 8/23/24
- Fixed applying sort mode to popover menus
- Fixed adding to Watchlist from menus
- Fixed flicker in progress bar
- Removed freeform window scaling
- Fixed activating search in Library
- Improved artwork size and spacing on Home
- Fixed changing playback speed in Advanced settings
- Fixed invisible Playlist and More button on prep-layback
- Fixed resuming playback after changing settings (visionOS 2)
- Fixed non-native style of buttons in Home screen navbar
- Fixed bottom menu when Multi-select is activated
- Removed unrelated options in Settings
What’s new in beta 4 (4935) 8/16/24
- Playback: Fixed missing playback controls on visionOS 2 beta
- Playback: Next Episode button now appears only with playback controls
- Home: New empty Home state designs (welcome screen, etc…)
- UI: Various UI improvements and cleanup
What’s new in beta 3 (4928) 8/9/24
- Metadata: Fixed artwork fetching on visionOS 2 beta
What’s new in beta 2 (4916) 8/2/24
- UI: Cleanup of various items
- UI: Multiple hover state fixes
- UI: Multiple color selector fixes
- Home: Added error grouping and auto-refreshing
- Home: Fixed item list visibility when errors are displayed
What’s new in beta 1 (4910) 7/26/24
- Playback: Improved design of playback controls
- Playback: Added saving of playback window size
- Playback: Fixed presentation of subtitles font selection window
- Home: Enabled new home screen with performance improvements
- General: Fixed a crash when changing sorting while browsing media servers
What’s new in alpha 2 (4902) 7/19/24
- General: Fixed Plex sign-in flow
- Playback: Fixed OpenSubtitles downloads
- General: Improved webviews for Trakt, Help Center, and Twitter links
- General: Other minor updates (visionOS is now merged into main code branch)
What’s new in alpha 1 (3) 7/12/24
- Playback: Added native Dolby Vision, HDR, and Dolby Atmos features
- Playback: Improved window resizing to respect video’s aspect ratio (and manual Aspect Ratio setting)
- Playback: Removed Zoom Mode setting as window size now automatically matches the video’s aspect ratio
- General: Latest updates from main Infuse version (EG Direct Mode, sort options, etc…)
- General: Many other improvements and fixes
Known issues
- Home: Missing PIN code support
- Minor UI issues for browsing and settings areas
- Some subtitles broken on visionOS 2
Many good things still to come. Stay tuned!
Happy testing!
