Infuse visionOS public beta - updated 10/4/24
I’m not on VisionOS 2 yet (but planning to as soon as it releases) and what happens is that every time i click play on a movie or TV series the app quits.
I solved the problem going back to Beta 8 which works fine.
I have the same problem. When I emailed, there was no response. The app crashes 100% of the time when I play any movie. My current OS is visionOS 2
No need to email just post the code here.
code:F2FMS
The build seams to have been removed from TestFlight?
I noticed there is no “Immersive Theater options” and also no even Features still in progress mentioned in the latest beta build.
Did you guys give up on the Immersive Theater?
These will be post-8.0 additions.
Sorry, an incorrect version of beta 9 went out last week.
Please try the 4963 version which is now available in TestFlight.
it works~
works for me as well
Beta 10 is up! :slight_smile:
What’s new in beta 10 (4968) 9/20/24
  • Updated video details page layout
  • More general UI cleanup throughout the app
  • Fixed updating Home screen after removing a share
  • Added Delete/Remove options to context menu on Home
  • Added PIN code support to Home
Known issues
  • Minor UI issues for browsing and settings areas
  • Some subtitles may not display correctly on visionOS 2
Note: This will likely be the last build that supports visionOS 1.x and all future builds will require visionOS 2.0 or later.
I fired off a bunch of crash reports when using currently active beta that was available when visionOS 2.0 went live. They were crashes resulting from clicking on entries on the Home Screen. These were resolved by removing all shares and setting up my Plex connection fresh. (OR a new beta build going out?)
I successfully watched two full movies yesterday with beta 9. Things are shaping up good. I’m really happy to see how much the player has conformed to visionOS standards.
I also had zero misfired taps or unexpected pauses for both movies. Very nice.
Beta 11 is up! :smiley:
What’s new in beta 11 (4976) 9/27/24
  • Improved subtitle handling and fixed issue with missing characters
  • Play button now appears on hover on Up Next items
  • Misc UI improvements
Note: Minimum version is now visionOS 2.0
Known issues
  • Minor UI issues
Is there an ETA on when to expect Immersive Environments?
Beta 12 is up! :slight_smile:
What’s new in beta 12 (4985) 10/4/24
  • Home: Fixed timely updating of lists (EG Continue Watching)
  • Home: Fixed updating series watched status after playback
  • Home: Fixed missing PIN when playing locked playlist via context menu
  • Preplayback: Fixed various UI issues
  • Direct Mode: Fixed episode layout for shows opened from Next Up
  • Direct Mode: Fixed a crash when switching Emby to Library mode
  • Direct Mode: Fixed updating content on Home after switching direct mode ON/OFF
Note: This is this first build fully built with Xcode 16. Let us know if you see any weirdness.
