Infuse Upscaling with AirPlay, Google Cast, and HDMI Output
Does the Infuse upscaling algorithm work if you’re outputting the video using AirPlay, Google Cast or HDMI from an iPad Pro (A12X)?
Infuse’s upscaling should be in effect when connected via HDMI.
However, when playing videos via AirPlay or Google Cast the playback and rendering are done on those devices (outside of Infuse) so Infuse has limited control over how things are played. This is also why the format support for AirPlay and Google Cast is a bit more limited compared to what Infuse can handle when playing on device.
