Infuse to plex bandwidth issues
I have been using infuse and plex on my 4k apple tv and ipad with no problems for months.
I’ve gone to use today and its saying bandwidth too high, I’m on the same network and not remote streaming.
Could I get some advice please… I’ve looked for this topic but all in regards to remote streaming. I’m local on same network
my only solution to you is to use shares directly from infuse skipping Plex.
it would fix the problem.
I don’t have plex but I think that if you use the Plex “Connect to Plex” option in the shares setting you won’t have this issue.
It sounds as though you may have just created a new share connecting to your plex server through maybe FTP or another protocol.
You can see the procedure for connecting to Plex here
