Infuse stops playback when resuming from pause?
On Apple TV 4K 3rd gen? (the one without Dolby atmos)
Using Infuse with Plex Media Server direct streaming almost everything
If I pause a video and let it sit for a bit and resume playback, it will play for a few seconds and then exit back to the Infuse as if I stopped the video manually.
So far I haven’t been able to replicate this with the Plex app on Apple TV. Plex logs show “handleStreamRead code 2: End of file”
Has anyone seen this before?
I have the same issue on my ATV 4K (2017). The issue might’ve started after updating to the latest version of TVOS.
I set the streaming cache setting to Limited. It was in Legacy. So far it hasn’t stopped playback. I’ll keep an eye on it
Did this manage to work for you? I had mine set to auto, just changed it now, but I was wondering if this is a dead end.
I haven’t had an issue since I changed the setting
