Infuse : Sort in Collections or Playlist
Hello,
Could you explain to me how the files are sort in Collections or Playlist and how to change ?
Don’t know about Collections, but Playlists are by default sorted in the order they were added.
On the Apple TV you can long press on an entry and select the Reorder option to move the entry to a different position. This allows you to have full control of the order of items in your Playlist
Thanks for the informations
Infuse supports both TMDB collections and custom collections.
TMDB collections will be sorted by release data (oldest to newest).
Custom collections are similar to Playlists, as they will sorted based on the order of items added. Like Playlists they can also be reordered.
