Infuse skipping intro twice?
I’ve noticed lately that Infuse seems to be acting a bit strange with intro skip feature. I have the setting on Infuse to delay and then auto-skip. Past few shows I’ve clicked it myself before the delay finishes. What I see is that it will skip to the end of the intro marker, wait 1-2 seconds, then rewind to the end of the intro marker again.
Almost seems like a duplicate execution or a “stutter”. AppleTV is connected over WiFi as it’s not possible for me to get a ethernet cable in there. Speed test in Infuse shows 700Mbps+.
Infuse Pro: 8.4.3
AppleTV 4K: tvOS 26.4
Backend: Plex
Possibly related: Bug: Credits skipping broken after latest update
If you are seeing this happen in 8.4.4 can you replicate the issue and send in a report from your device (and post the code here)?
Hi @james sorry for the delay.
I am still seeing this issue on 8.4.4, but it’s not happening every single time now. The support bundle code is 021X9.
Want to note that I’m trying out Jellyfin and I haven’t noticed this same behavior yet. I’m not sure what Plex could be doing is this turns out to only be present with Plex backend.
I have more data.
It DOES happen on Jellyfin too, but I’ve only seen it when I hit the “Skip Intro” button manually instead of letting it auto skip with delay.
So @james the behavior seems to be backend-agnostic. It does happen rarely with auto-skip on delay, but it’s very rare. When pressing the skip button manually, it backs up a second or two and skips the remaining 1-2 seconds of the intro marker. That’s why it seems to be skipping twice.
