Hi, I scraped a series using TinyMedia Manager, but Infuse keeps showing me the wrong series.
What could be the problem?
The most common problem in metadata errors is the way you have the files named. If you provide a sample of how you have the file(s) named we can take a look.
So, I searched for the series “Dream of Italy” in TMM, the data was found and written to the folder.
When the folder is displayed in Infuse, it shows a background from a completely different series, and I can’t change it. The poster for the folder is only shown for the wrong series, but not the file I have in there as folder.jpg.
Currently Infuse doesn’t support customizing TV shows with nfo files but there is a suggestion thread that is requesting this feature.
Don’t forget that you need to click the like button on the first post in that thread to show your support for that suggestion! ![]()
Another option would be to add this series in TMDB where Infuse pulls it’s metadata from. Then it’d pull the right metadata for you and anyone else that has this series. That’s one of the benefits of community supported sites like TMDB.
Hmmm there ar NFO Files on the picture. with the data to the file
Infuse currently does not support nfo files for tv shows.
