I had to re-install everything on my iMac after its library got corrupted. That went quite smoothly. Only thing is: I cannot seem to connect my Apple TV 4 to the movie folders on the iMac anymore. Whatever I try, I get the error ‘name and password combination not correct. CLOSE’. (I had to create a new user on the iMac, but on the computer, this runs okay. To connect Infuse on the Apple TV with the iMac I tried every possible login name and password, including the old ones of course).
The Apple TV does see the iMac though; I can open iTunes and Computers to play the movies and music that are parked there.
Finally, I uninstalled and re-installed Infusie Pro. To no avail… ![]()
I do hope you can help me out (so I can proceed with the next problem: re-connecting the printer…)
Thanks for your help!
