When playing video how do you skip to the next video. The arrow on the onscreen navigation only jumps forward or back. I want to easily skip to the next video?
How can i tell the frame rate of the video? Only infromation is resolution = HD/4K and file format.
When I select Folders in favourites i can only delete. No option to move. Also cannot move files in favourites.
I want to create a playlist by selecting multiple files on one go? i can only do this via indiciually selecting which takes ages.
These features are not supported at this time, but you may consider following and supporting these topics in the Suggestions area.
