Just switched from Sheild TV and Kodi. I like how easy it was to set up Infuse. I do have a simple question however. Is it possible to mark folders for what content they have? For example, if you have multiple TV folders, can you mark them all as “TV Content” and make them show up under the “TV Shows”.
As long as your not using DLNA to connect and are using say SMB then Infuse will recognize all TV shows regardless where their at an display them in the Library under TV Shows. You don’t have to mark the folders in any special way. You do need to follow the correct file naming rules and use the proper folder structure found in the users guides.
