I have a Lifetime subscription and have 4 Apple 4kTVs connected on a family account.
One of those units is having a problem and saying that Infuse Pro is required.
I’ve updated all the software - ios 12, tvos 12, infuse app re-logged into trakt tv and even deleted the app and reinstalled everything from scratch…it will just not sync up. The other 3 units work fine.
Would removing the person from the family account and then re-add them solve this? i don’t know if there’s a limit in regards to Apple allowing to remove and add over and over so i’d like to know before taking this step
There are two different versions of Infuse. Infuse and Infuse Pro. You have to have the same on all devices. Sounds like you may have different ones. If you have the lifetime sub you want plain Infuse not the pro. Then you restore the lifetime sub.
that’s what i’ve downloaded…i was the initial downloader, then created the family account, then had each of the other users download it using the family purchases page so there would be no mistake
Edit to add, just found an Apple support page that says 10 devices can share BUT it seems that it totals devices used by each member of the family that is sharing so the way I understand it, if Dad has 3 devices on his icloud account and Mom has 3 and the two kids each have 3 that would be a total of 12 and that would be over the 10 device limit.
Here’s the Apple page that I’m referring to and it’s not real clear but that seems to be the answer.
