Infuse Pro Features are Unclear
New Apple TV owner and recently downloaded Infuse to stream from two external movie drives I’ve set up.
Have different file types, including .m4v, .mkv, .wmv …
When I try and find out what is a benefit of Pro, I’m only see general high-level statements about “more” and “better.”
Is there a link to the specific added functionality of Pro?
Thank you,
An overview of what’s included with Pro can be found here.
Yep, thanks. I saw that. That was pretty high level. Exactly which file types are added with Pro, as an example.
There isn’t a definitive list of which videos require Pro, as there are some complicated factors that determine if a particular video requires Pro. For example, one MKV may play in the free app but another requires Pro. Likewise with AVI, WMV, M4V, or MP4, some play in free while others require Pro. It really comes down to the actual codecs of the video/audio streams contained inside the file.
Thanks. That helps a lot. I really don’t know much about this but I’m trying to learn.
I took a bunch of movies I bought (store, swap meets, etc.) and ripped them using either Handbrake or MakeMKV. Those were the apps I read about on the web. MakeMKVs are bigger and look a LOT better!
So those are the only two sources of digital movies I currently have (though that will probably change now that I have the Apple TV).
But could I assume that the individual “codecs” you mention are the same within all of the Handbrake files (.m4v) and are different but all the same within the MakeMKV files (.mkv)?
Because the .m4v files are playing fine but the two .mkv files that I tried don’t.
Would you guess that I’m “okay” with what I’m doing for my Handbrake process (if they are all the same Handbrake to Handbrake session) but should buy Pro for any of the MakeMKVs … given that they don’t seem to work … and would be the same ripping, session to session?
I could see Handbraking things that I only want to watch on a plane on my iPad or iPhone …and MakeMKVing things that I care more about and would likely want to watch again on my Samsung TV.
Thanks again,
Generally, discs will usually contain codecs that require Pro, and the default Handbrake settings will convert these to formats that work in the free version. This is an overgeneralization, as some discs contain codecs that work in free and Handbrake can covert videos to just about anything, so it’s possible to make something there that requires Pro.
Personally, I think it’s best to limit how much converting you do to retain as much of the original quality as you can. With MakeMKV, you’re creating a 1:1 copy without zero quality loss. Once you introduce Handbrake, you are losing some quality. Some are ok with a little extra effort if it means they can use the free version, others prefer to avoid the extra step and watch things in the highest audio/video quality possible.
Makes perfect sense.
So if I’m understanding all of this correctly, my current MakeMKVing process is creating top-notch movie files, which is the right thing for those I plan on long-term viewing.
And since the two MakeMKVs I looked at wouldn’t run, it looks like I need Pro?
Pro will run all of my MakeMKVs, right?
Just checking to make sure I didn’t miss something here. lol
Yep, you got it. :slight_smile:
Also, using MakeMKV is generally faster than Handbrake too since it’s not doing any conversion.
Aces! Thanks!
