Infuse Pro fails to load certain series on my Plex server
Hello, I’ve been getting the following error whenever I try to load certain multi-seasonal anime on my Plex server, like Jojos Bizarre Adventure or Demon Slayer. This is just when loading the series menu, not when playing an episode. It happens on both MacBook and iPhone apps. It seems to be failing to parse the folder structure of the episodes, but it works for other anime like Bleach with a similar folder structure. Any ideas how I can fix this? Thanks.
Error message:
The operation couldn’t be completed (infuse.PrePlayblack.RepoLoaderViewModelPlexSeries.LoaderError error 1.)
Also, sorry about the double post. Misclicked the delete button on my first post.
Are the affected items in a specific library or is it just this one specific series?
Which metadata agent in Plex are you using for this?
Not in a specific library or series. I have 8 libraries in my Plex server, 4 with movies and 4 with TV shows. All of the movies load properly.
For the TV shows, a couple of the ones with multiple seasons throw this error when I try to load them. A few of the ones I’ve seen do this: The Boys, Demon Slayer, Jojo’s Bizarre Adventure, Stranger Things, Attack on Titan. Some of the shows with multiple seasons still load properly though, so not all of them are failing.
For metadata agents, I see it set to “Personal Media Shows” on Plex, but I believe Sonarr used thetvdb to download them (I see that tag on the filenames).
Hi, any suggestions for this? I’m still getting the error :confused:
do they play correctly when using the plex client app or on plex web?
are you using infuse in direct more or library mode when connecting to plex?
does the folder structure or file names have any non alphanumeric characters?
It works on both Plex client and web
I’ve tried both Infuse direct and library mode. I’m trying to open the show through the Files tab.
Folder structure:
Demon Slayer - Kimetsu no Yaiba (2019) {tvdb-348545}
Season 01, Season 02, Season 04, Season 05
Here are the file names:
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E01 - 001 - Cruelty [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E02 - 002 - Trainer Sakonji Urokodaki [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E03 - 003 - Sabito and Makomo [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E04 - 004 - Final Selection [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E05 - 005 - My Own Steel [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E06 - 006 - Swordsman Accompanying a Demon [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E07 - 007 - Muzan Kibutsuji [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E08 - 008 - The Smell of Enchanting Blood [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E09 - 009 - Temari Demon and Arrow Demon [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E10 - 010 - Together Forever [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E11 - 011 - Tsuzumi Mansion [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E12 - 012 - The Boar Bares Its Fangs Zenitsu Sleeps [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E13 - 013 - Something More Important Than Life [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E14 - 014 - The House With the Wisteria Family Crest [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E15 - 015 - Mount Natagumo [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E16 - 016 - Letting Someone Else Go First [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E17 - 017 - You Must Master a Single Thing [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E18 - 018 - A Forged Bond [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E19 - 019 - Hinokami [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E20 - 020 - Pretend Family [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E21 - 021 - Against Corps Rules [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E22 - 022 - Master of the Mansion [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E23 - 023 - Hashira Meeting [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E24 - 024 - Rehabilitation Training [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E25 - 025 - Tsuguko Kanao Tsuyuri [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S01E26 - 026 - New Mission [Bluray-1080p][10bit][x264][AAC 2.0][EN+JA]-LostYears.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S02E01 - 027 - Flame Hashira Kyojuro Rengoku [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S02E02 - 028 - Deep Sleep [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S02E03 - 029 - Should Have Been [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S02E04 - 030 - Insult [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S02E05 - 031 - Move Forward! [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S02E06 - 032 - Akaza [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S02E07 - 033 - Set Your Heart Ablaze [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E01 - 045 - Someones Dream [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E02 - 046 - Yoriichi Type Zero [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E03 - 047 - A Sword From Over 300 Years Ago [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E04 - 048 - Thank You Tokito [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E05 - 049 - Bright Red Sword [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E06 - 050 - Arent You Going to Become a Hashira [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E07 - 051 - Awful Villain [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E08 - 052 - The Mu in Muichiro [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E09 - 053 - Mist Hashira Muichiro Tokito [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E10 - 054 - Love Hashira Mitsuri Kanroji [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S04E11 - 055 - A Connected Bond Daybreak and First Light [Bluray-1080p][10bit][x265][PCM 2.0][EN+JA]-iAHD.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S05E01 - 056 - To Defeat Muzan Kibutsuji [Bluray-1080p Remux][8bit][x264][FLAC 2.0][JA+EN]-CRUCiBLE.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S05E02 - 057 - Water Hashira Giyu Tomiokas Pain [Bluray-1080p Remux][8bit][x264][FLAC 2.0][JA+EN]-CRUCiBLE.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S05E03 - 058 - Fully Recovered Tanjiro Joins the Hashira Training!! [Bluray-1080p Remux][8bit][x264][FLAC 2.0][JA+EN]-CRUCiBLE.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S05E04 - 059 - To Bring a Smile to Ones Face [Bluray-1080p Remux][8bit][x264][FLAC 2.0][JA+EN]-CRUCiBLE.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S05E05 - 060 - I Even Ate Demons [Bluray-1080p Remux][8bit][x264][FLAC 2.0][JA+EN]-CRUCiBLE.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S05E06 - 061 - The Strongest of the Demon Slayer Corps [Bluray-1080p Remux][8bit][x264][FLAC 2.0][JA+EN]-CRUCiBLE.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S05E07 - 062 - Stone Hashira Gyomei Himejima [Bluray-1080p Remux][8bit][x264][FLAC 2.0][JA+EN]-CRUCiBLE.mkv’
‘Demon Slayer - Kimetsu no Yaiba (2019) - S05E08 - 063 - The Hashira Unite [Bluray-1080p Remux][8bit][x264][FLAC 2.0][JA+EN]-CRUCiBLE.mkv’
Hi, would anyone be able to help with this please? Thank you.
