Infuse Pro crash airplay to appleTV
When I stream from my iPhone 6 or iPad Air to my 3rd generation appleTV, most of the movies or series get stuck after 10 / 15 minutes. When I close the infuse app and restart it, it will continue playing from the point it had crashed. 10 to 15 minutes later it will happen again and after that again… My files are on a Windows 10 pc (i7, 8gb, 64bit). I had the same problem when Windows 7 was running on my pc. I’m using Infuse Pro v3.4.1.
Is there a way to solve this problem? Thanks!!
Hmm, sorry about that. Is this still happening in Infuse 3.5?
Same here Opened a ticket and got no reply
