Infuse Pro - ATV4K - Macroblocking issue in dark scenes after 1-2 minutes
Hello there,
weird issue here:
I was watching Dune 2021 in HDR10 yesterday and saw some strange thing in terms of macroblocking in dark scenes on my LG OLED C9 starting to show up after 1-2 minutes playtime. There is also macroblocking while watching the Dolby Vision version.
I’m using Infuse Pro 7.2.1 (3874) and ATV4K (tvOS 15, 19J346). If I restart the app completely and jump to dark scenes (like at 21:10min) there is no macroblocking visible. Then while watching 1-2min more I see when this macroblocking issue shows up out of sudden. If I jump back to 21:10 I can see ugly macroblocking, a harsh transition from black to dark greys, especially on cloths in dark scenes.
This is NOT happening when I use the PLEX app on my ATV4K, or when I use the internal PLEX app from the TV, or when I watch it directly from an USB stick. So this must be an issue of Infuse.
I also noticed some heavy flickering like two times last week while watching “The Arrival”, in the Helicopter scene starting from 16min. I wasn’t able to replicate this though.
Anyway, there is something going with Infuse here I think. I never had an issue with Infuse before that. Feels very new.
DUNE:
  • Bitrate 19108 kbps
  • Width 3840
  • Height 2160
  • Aspect Ratio 1.78
  • Video Resolution 4K
  • Container MKV
  • Video Frame Rate 24p
  • Video Profile main 10
  • Duration 2:35:54
  • File pso-dune_web.2160p.mkv
  • Size 20.81 GB
  • Container MKV
  • Codec HEVC
  • Bit Depth 10
  • Chroma Subsampling 4:2:0
  • Coded Height 2160
  • Coded Width 3840
  • Color Primaries bt2020
  • Color Range tv
  • Color Space bt2020nc
  • Color Trc smpte2084
  • Frame Rate 23.976 fps
  • Height 2160
  • Level 5.0
  • Profil main 10
  • Ref Frames 1
  • Width 3840
  • Display Title 4K (HEVC Main 10 HDR)
  • Extended Display Title 4K (HEVC Main 10 HDR)
ARRIVAL:
  • Bitrate 62920 kbps
  • Width 3840
  • Height 2160
  • Aspect Ratio 1.78
  • Container MKV
  • Audio Profile ma
  • File Arrival (2016)_t00.mkv
  • Size 51.22 GB
  • Audio Profile ma
  • Container MKV
  • Codec HEVC
  • Bitrate 52808 kbps
  • Sprache Englisch
  • Language Tag en
  • Bit Depth 10
  • Coded Height 2160
  • Coded Width 3840
  • Color Range tv
  • Height 2160
  • Level 5.1
  • Profil main 10
  • Ref Frames 1
  • Width 3840
Can you check to ensure both Match Content options are enabled on your Apple TV?
These are disabled by default, and can become disabled at times when installing tvOS updates.
Thx for the reply. I found the issue. It is the Apple TV itself. Same behaviour on a different TV and also issues with the Plex App (sometimes steady and heavy flashing/flickering in dark scenes when I start the app). NO issues on the new Apple TV.
