Hello,
i can’t seem to find the google cast feature in the sidebar settings menu… Is this normal? Do you know why?
This is the only reason I bought the Pro version so I hope it’ll work.
thank you
The sidebar setting was only present in the earlier versions, while Google Cast support was in beta.
As of 3.3, Google Cast is no longer in beta and the option to Cast will be visible in the lower right corner when a video is playing.
Same here, the feature doesn’t appear even if my connection is good, my Chromcast is available on other apps … Don’t know what to do
The Cast option will only appear if the currently playing video is eligible to be Casted.
As of now, Google Cast currently supports h.264 and VP8 video formats.
2 posts were split to a new topic: Google Cast button missing
