I see infuse says that you can stream videos using airplay when app on background, but whenever I switch to another app or I suspend the ipad the video playback stops.
How can I use this feature?
Thanks,
Regards.
Thanks,
Regards.
Sorry for the confusion. Infuse supports 2 types of AirPlay. Native and mirroring.
Native AirPlay will support any video that is h.264…even if it’s an MKV, and will work in the background.
Mirroring can be used for some of the more obscure formats, like WMV, but will not work in the background.
Infuse will always auto-select the best method to use.
Hope this helps.
Thank you very much for the explanation. Everything is clear now
