Hi Firecore Team! Infuse Pro 5.6 is looking great. Thanks so much for the effort you guys put into it.
I have a couple of questions for you, both pertaining to specifics around the iPhone X :
The swipe Bar at the bottom of the video stays on the screen all of the time right now. I have noticed that in other apps when playing video it will auto fade. Can you guys do this too? It sure would make viewing a lot more pleasant.
I have also noticed in Apple’s default video viewer that the default zoom mode is set so that the video does not overlap with the “notch” area, but allows you to double tap the screen to zoom in should you desire to use the whole screen. While I suppose I could get used to seeing the notch over there it sure would be nice to have the option to not see it. This seems to only be the case for some aspect ratios. More testing may be needed to understand when this is occurring.
It would be great if you could indicate if the movie is HDR (10-bit) somewhere on the screen when flipping through them.
What happened to showing us the resolution of the movie? That was one of the features that set Infuse apart from the competitors and now it appears to be missing! Please bring this back. (I see that this data is there in landscape mode but not portrait.)
Thanks in advance for taking the time to hear out your customers.
