Infuse on Vision Pro not working after update, Please Fix
I was going to write about other smaller issues but guess what, it stopped showing up completely today. When I open the app, it’s just a transparent window of nothingness… Please see the attached video. Not something I would expect from Infuse.
Since I’m new here, please let me know how to make the staff see this post and fix it. I mean this must be an urgent bug right? Any other Vision Pro user having the same issue?
Did you restart the vision pro? Did you also just update to OS 27?
If a restart didn’t fix it then it looks like the update for Infuse got corrupted. Deleting the app and reinstalling it may be needed.
Edit to add, I don’t have AVP but the symptoms are similar to other devices with corrupt updates.
update: the newer version update solves the issue!
