Infuse not working for LPCM and PCM 2.0/5.1 audios
Whenever I load the contents with LPCM 5.1/2.0 and PCM 5.1/2.0, the video keeps freezing and faster get “an error occurred loading content” and the download quota exceeded.
The med info I posted here
Audio #1
Format : PCM
Format settings : Little / Signed
Codec ID : in24
Duration : 45 min 30 s
Bit rate mode : Constant
Bit rate : 1 152 kb/s
Channel(s) : 1 channel
Sampling rate : 48.0 kHz
Bit depth : 24 bits
Stream size : 375 MiB (1%)
Title : Apple ����ý�崦����� / Apple �������ݴ������
Language : English
Encoded date : UTC 2022-03-31 07:07:06
Tagged date : UTC 2022-03-31 07:11:34
Audio #2
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Audio #3
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Audio #4
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Audio #5
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Audio #6
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Audio #7
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Audio #8
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Audio #9
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Audio #10
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
I can upload the sample for testing if needed.
It would help to tell us what version number of Infuse you’re using and on what device and device OS.
Also, what type of video, mkv, mp4, mov, etc.
Is this on a remote server like Google Drive or another cloud service or is it on a LAN?
